1 - 10 of 10 Posts
Long story short , I have a 2006 G6 GTP with 65000 miles on it, after a rebuild transmission ($2000). P0011 new camshaft sensor instslled by dealer $300 bucks !!New plugs and wires, oil change done, new air filter, new battery installed, I'm only getting an average of 200 up to 220 miles per tank !! And I've noticed a lack of power !! And ideas on what it can be ??? I'm thinking maybe thermostat stuck open ?? Or maybe I need a new catalytic converter ?? Or maybe the computer needs to be upgraded with new software ???
Yikes.....that sucks. I would drive it back to the dealership and ask them what they
did to crap up your HP & MPG's...
yea check with the dealership.
Any other trouble codes? Your cat could be clogged up... Does it run fine up until you try to drive it?
One day after a long enough drive you can try to open your hood and take a look. The cats can glow if they get hot enough...
Computers usually don't need to be upgraded unless you're looking for performance gains.
Hopefully it gets resolved!
Okay, I tried looking at the cat after a long 2hour expressway drive and I didn't see the cat glow red, I put a OBD2 scanner on it and no codes come up, all monitors come up as good, I really think its the cat or maybe the oxygen sensors possibly any input guys ????
Hmm. the cat could still be at fault. Slightly clogged, enough to rob power and MPG but not enough to get super hot... I would assume it would throw a code.
I believe there is a test where you can hook up a gauge in place of the first o2 sensor and measure the back pressure in the exhaust. You may then be able to determine if it is bad.
as for specs on how much pressure, or the tools i'm not too sure. Maybe autozone has one you can rent?
Thanks for the info , I'll see tomorrow if I can get a muffler shop to perform that particular test
I have a 06 GTP coupe as well, 75,000 miles. I have the 6 speed trans and I am averaging only 15.6 MPG according to the display. I always keep up on my maintenance and there car seems to be in good working order (no codes, no driving problems, no loss of power). I've been wondering why its been so bad too. Let me know what you find out, its possible we have the same problem. Thanks!
Discussion Starter #9
Cswild26 I'll keep you informed !! CrusinG6 thanks alot I'll also keep you informed !!! Thanks for all the info
1 - 10 of 10 Posts
