Clean lenses with glass cleaner and dry completely. Scrub off any stubborn debris or staining with a scrub brush.
Spray lens and film with soapy water. Lay the film over the lens.
Apply heat from a heat gun while rubbing the film with a small squeegee. Work from the center out.
Trim the excess film with a razor blade around the edges of the lens. Apply heat to the edges to seal.
ummmmmm
I use electrical tape and push it into the small outline of the reverse light than use a excto-knife or a box cutter and trace the outline.. Peel away the extra tape and spray away
Sent from my SCH-I510 using AutoGuide.Com Free App
