I currently own a 2007 Pontiac G6, 233,000 miles and it came with factory installed 17x7 wheels and 225/50/17 tires. Is it possible to switch over to a comparable wheel size and tire size to change the size from a 17" tire to a 16" tire? If so, what's the recommendation for sizes? And will it change the handling and/or performance? Will it affect the front end suspension or anything else that's critical I should know about?
I'm tired of having to purchase 17" tires when it's hard enough finding a decent price in my area, never mind a decent/good tire rating.
08 convertible
Sure it's possible. 225/55/16 is the same diameter within 0.5% .
Yes it will change handling slightly.
The questions you must find the answers to are:
1. Will a 16" wheel clear my brakes?
2. Am I going to save enough on tires to cover the cost of new wheels and still be ahead?
No problem at all. Go with 16" wheels with 215/60-16 or 225/55-16 tires. The 60 series tires will be cheaper. The change in handling will be negligible.
Just go on the net and search for a “tire size calculator”. When you find one like, plug in you current tire size and the wheel size you wish to go to. I think you will like the results.
You should still keep in mind what dxG6 and waterfowler mention in their posts.
Which wheel and tire packages did you end up getting? Most of the time, I use the customer support page of the shop where I plan to buy car parts and accessories. Their representative knows which package fits my budget and my vehicle.
Hello katlunsford – What Wheels and tires did you end up using? I wish to do this too!
