Does anyone know the the traction control button itself works? I understand TC. I mean the actual button. Is it a simple positive and ground behind there? Got a great idea from the Noble M600 and I'm curious to know if you can swap the button out for something cooler. say something that looks like it fires a missile instead of turning off your TC. Anyone pull it aprt and take a look? Any info would be great. Thanks guys.:cool:
The TC button has 3 wires going to it. A Black wire to Ground, a Gray wire for the illumination, and a Brown/White wire that goes to the BCM. Pressing the TC button connects the Brown/White wire to Ground.
So any momentary switch that completes a circuit as long as it's depressed will work for the same job.
