· Procrastinator
When I turn on the air in the car, whether its with A/C or not, I can't use setting one, nothing comes out. Settings 2-4 work fine. I have helped people fix this problem with other vehicles. Usually from over using the setting and causing a short or corrosion build up on the connector. Does anyone know where the resistor(at least I think it is) pack for this is?
· Slick Black Pontiac
Have you tried using electrical contact cleaner on the switch itself?
I had another car that this problem happened to after a large McDonalds sweet tea was spilled into the console... Long story.
Anyway, I pulled the whole switch panel out and used electrical contact cleaner on the switches from the back and they worked fine after that.
· Procrastinator
I haven't tried that. I haven't even pulled the side of the center console off to look in there yet. Work has had me busy lately and it happened fairly recently. I will look and see if it is just 'gunky.'
