Tried opening top and trunk only opened a few inches and stopped. Had just added oil to an empty pump reservoir, lifted trunk manually all the way up and now it is stuck half way up and nothing happens except flashes top not secure.
Any pointers on what to do.
Super Moderator
If you have had to refill the pump reservoir it is fairly certain you have a hydraulic leak somewhere. The most common leaks are the main rams that move the roof. That said, the issue with the trunk stopping mid reverse open is more commonly related to a sensing issue. Many of us have experienced cracked or broken wires in the trunk, especially near the hinges. A visual inspection may enable you to spot this.
Hope you can find and fix the problem
