I just purchase a 2005 Pontiac G6 with 32000KM (19000 Mile) and I did not notice these 2 problems when I test-drove it. There seem to be something ticking in the Dash, seem like every time I accelerate I hear this ticking noise in the front dash, sounds like an electrical ticking, also maybe related, the other problem is my speedometer is ticking as it goes up by 5kms at a time. Has anyone else had these problems? Apart from these 2 little problems (I hope) I love my new car!
i'm pretty sure it's your heater ... i have the same noise ... try to turn the heater off and see if the noise goes away
goforit01-21-2008, 07:49 PM
Hi, I finaly go more information on the ticking noise in the dash, ( no thanks to the dealer) I found this info on "GM inside news" It turns out that this problems has a TSB # (technical service bulletin)for this problem: 04-08-59-003A. It turns out it's not a big problem just a bit annoying. This is the fix :
Front of Dash Clicking, Ticking or Cracking Noise During Warm Up in Cold Weather (Install Squeak Reduction Tape) #04-08-59-003A - (Apr 20, 2005)
2005 Pontiac G6
This bulletin is being revised to change the description of the condition. Please discard Corporate Bulletin Number 04-08-59-003 (Section 8-Body and Accessories).
Condition
Some customers may comment that in cold weather , especially as the front windshield defroster duct air warms up the vehicle, they hear a clicking, ticking, or cracking type noise from the front of dash.
Cause
Thermal expansion/contraction may cause this noise. The expansion may be between the dash carrier and the clips attached to the trim panel (defroster grille cover) or the clip to the trim panel (defroster grille cover).
Correction
Remove the windshield side upper garnish molding by unsnapping the plastic cover at the top. Remove the screw and pull inward to release the center retaining clip on the molding.
Remove the trim panel (defroster grille) following SI Document ID #1470558. The drawing shows 10 clips. The G6 has 8.
Remove the retaining clips (8) from the trim panel and apply 3M™ Squeak Reduction Tape to the towers of the panel and reinstall the clips.
Apply 3M™ Squeak Reduction Tape into the slots (8) in the IP.
Reinstall the trim panel.
Reinstall the windshield side upper garnish molding.
Parts Information
3M™ Squeak Reduction Tape, P/N 06356, can be purchased locally.
Warranty Information
For vehicles repaired under warranty, use:
Labor Operation
Description
Labor Time
C2368
Grille, Defroster Outlet
Use Published Labor Operation Time
I will be bringing it back to the dealer for the fix.
