Drove to work noticed clock kept resetting. When I got to work turned car off, went to turn to on had nothing. Tried to crank it and nothing at all. Any suggestions
The battery terminals may be corroded and not making a good connection , check and clean them . If you turn the key to on and don't see the battery icon appear on the dash this often points to a failed connection at the battery . The video shows some additional tests to try also .
