1 - 16 of 16 Posts
Lol, so i ran seafoam through my brake booster line yesterday. I thought it was supposed to produce a bit of steam/smoke from the exhaust? I disconnected the brake booster line from block and put a 1/2' hose on put my thumb over it started her up...sucked in 1/3 of the can of seafoam while my buddy revved to keep the idle clean and then shut it off for 10 min or so. Re-connected the hose...started it up and no smoke/steam....not during the process or after when i restarted the engine and gave it a little gas.
Two things...
first...is this simply because i opted not to put it in the oil also? i know that you should only put it in the oil right before your going to change it and run it till theres no more smoke/steam and then change your oil.
or second....and worse....could the no steam/smoke be from a leak somewhere in my lines? or did i simply just not do it right...
that was my first time running seafoam through the car..i did have several techs from small auto shops telling me what to do and a few people observing who have built turbos and have a bit of experience running seafoam. but they had only done it on 4 cylinders....
i know it said to consult a tech to make sure it would reach all 6 cylinders before doing it...could that also be why there was no smoke/steam?
thanks in advance for your help duders...
Seafoam in your oil is a horribly bad idea. Vacuum is the only way I'd ever consider seafoam and even still my personal preference would be GMs TEC if I were to ever do it.
Well everyone whos done it or the mechanics ive asked said to do a full seafoam treatment you run 1/3 gas tank.. 1/3 vacuum and 1/3 oil you run it till the smokes gone and then you change your oil the same day.
im curious though why wouldnt you run it through your oil? what potential damage could it cause if you change the oil an hour later?
Seafoam removes gunk out of your engine. This is good. However where does the gunk form? Gunk sticks to cold areas of the engine which are not near friction creating components. When seafoam frees it up the build up breaks into smaller deposits and circulates throughout you're oiling system. The particular area for concern are you main and rod bearing oil passages. The tolerances in most modern engines for bearing clearances are less than or equal to .0001". Loose lubrication to a main or rod journal bearing and your looking at total engine faliure.
I run seafoam in my oil, But only for about a week or so before I change my oil, Gives it a chance to knock everything loose in time for the change so the fresh oil can stay nice and clean. I would think by doing this every oil change you don't really give gunk a chance to build up enough to where you'll see problems.
As for the white smoke, From what I've read that is actually steam coming from the simple combustion with the moisture. But I could be wrong, Just what I've read.
Gunk build up wont be an issue if you run the motor hot enough(good driving cycles), use premium quality oil, and stick to a regular oil change interval. It's basically a waste of money. That's just my 2 cents however. A piece of mind is always a valuable asset and that's what it brings people. You also have a point about the repetitive use. I can't say I've ever heard of issues with seafoam from owners whom use it often and early. Mostly people whom use it first time on an older car. Googling "engine knock after seafoam" should raise some eyebrows however.
Discussion Starter #9
Well Metalhead it seems you have a thorough knowledge of the inner mechanics of the engine itself so i definitely take your advice as fact.
My question is this
i have an engine with 95 k on it and is running with a serious lag. it just seems like its clogged up. I try to keep it as clean as possible and stay up on oil changes and what not. I dont change the tranny fluid as much as i should given its such a bitch to get to. But its running like its dragging. Sometimes i mash the pedal and get no response ...ill let off mash it again and it will eventually jump into gear.
from what your saying it seams like running the seafoam through my oil prior to changing my oil could seriously damage my engines internals?
what would you recommend to try and repair a really sluggish engine?
It could be any assortment of issues from a fuel filter, TPS, dirty MAF. The only way I could say anything is to have hands on diagnosis. Running seafoam via a vacuum port isn't going to harm anything. The stumble sounds like an air related issue but again you can't tell via text.
Discussion Starter #11
yeh i know what you mean. Ive never pulled the mass air flow censor out to check it or the tps...would it look dirty or wouldnt i get a light on my dash if it was malfunctioning?
in lamenst tersm, i feel alot of exagerated gears. sometimes it holds an 2 or third gear especially going up hill for wayyyy to long before finally jumping into the next gear and i usually have to push down excesively to get it to jump into its next gear up hill.
not to say the car runs like shit...some days it runs amazing...some days i just dont get the power and it feels clogged.
Have you checked your throttle body? I'm at about 46k right now and I've cleaned it I think 3 times now. And every time I'm amazed by the difference! even a little bit of gunk is enough to slow mine down IMO.
And Metalhead I can see where you're coming from on using the seafoam on a high mileage engine for the first time. Maybe piece of mind is all I'm paying for but my last oil change (going by the life indicator in the DIC) the old oil was still pretty darn clean, and this was after about 6-7k I think, not sure.
Slick Black Pontiac
Definitely check your air filter. I didn't realize how much of a drag it put on my engine until I changed it, what a difference. Also definitely look into cleaning your throttle body it sounds like it has gunk built up on it by the way you have to floor it to get it to move. The throttle in the G6 is by wire, that is, electronic, not a cable from the pedal to the throttle so it may be a case of the throttle stepper motor getting weak or just very gunky.
Discussion Starter #14
sorry for the shitty spelling/grammar im trying to speed post these in between my boss looking over my shoulder
Discussion Starter #15
Metal your a god that sounds like the problem to a T. what should i do to clean it. Mind you i have some but limited experience in ripping my car apart to get to the gold if you know what i mean.
just a basic over view would be very helpful
Discussion Starter #16
also, i dont think its my air filter...i change it regularly and if its dirty i clean it or replace it. but i do wonder if my actual intake is getting gunky. Ive never actually pulled that apart and dont know if it would do any good anyway.
ideas?
also in your opinion...is it worth anything to get a K&N CAI? (since i cant get crabbs anymore)
Im not a real big fan of the fart can sounds...but if it will help my car breathe better im all for it..
still my buddy has a 07 camry he threw one on...now he blows black smoke when starting from 0 and trying to muscle threw his first couple gears....he also ran rich for a long time and it took his ECU a while to relearn everything...oh and he had to get a new MAF cuz it got wet.
pros/cons worth it?
1 - 16 of 16 Posts
