Hey guys,
been doin work on my car since my license is suspended for a month so i have a list of things im planning on doing, one of witch being fixing my headlight which has water trapped in it...is there anyway of fixing this? or do i have to buy a new one?
Thanks for any help
Mike
I would say the easiest thing besides opening up the headlight. would be to take the light off the car, take off the bulb covers, and take out the bulbs and see if you can get the water out through one of the holes. Then just let it dry or use a hair dryer.
And after its all dried out use the hair dryer again and heat up the seal on the headlight all the way around and use big clamps and hold the light toghter to hopefully fix and broken seals. Hope that makes sense.
· GTP 06
take the bulbs out and put some rice in a cloth thin towel in with a little hanging out to be able to remove. that will absorb the water. you can then use a hair drier to dry it out. Or fill a box with rice and submerge the light in it for a couple days.
