1 - 20 of 46 Posts
Well after having the car since September and just a tad under 10K miles. My Car is starting to leak right behind the passenger seat and drivers seat right above where the seatbelt comes out of the side panel. It was pouring here today and I noticed it when I came out of the store. So Im going to call the dealer tomorrow and make an appointment. Its either getting in from the window or the sunroof. Its closer to the side windows. Has anyone else had this problem on the coupe?
I must not have any luck with pontiacs. My last pontiac was a 87 formula and the t-tops leaked on that too. :(
Discussion Starter · #6 ·
Dropped the car off today and they took care of it in a couple of hours. The cause was They found drain tubes dislodged from the main drain tubes from sunroof, They said the assembly was too tight and didnt have enough play and would pull out again, so they pulled on the tubes giving them a more relaxed assembly and re-attached them to Main part, They redid the water test and found no more leaks. "All back to GM Specs"
Hopefully it fixed the problem. Well it looks like it will rain again tomorrow and friday, so I guess I will see then.
They also took care of the recall for the sun visors.
i have this problem as well. i hope to fix it myself. don't feel like giving up the car to the dealer for a day or two for something i could much more satisfactorily do myself, but we'll see...
what's this sunvisor recall they mentioned up top?
Yeah, hard to apply makeup when driving if the vanity mirrors won't stay open. It could cause a wreck ;)
I had another flood in my back seat last night, so I sucked it up and dropped the car at the dealer. They said they knew it was the roof drains, and that they had become experts at fixing dislodged and clogged drains. I was assured after this fix I should NOT have to revisit this issue again!
Just dropped mine off today, told them that any time it rains or i get my car washed the passenger side seat belt gets soaked. We'll see how it goes, hopefully they will fix it right the first time, needed my oil changed anyway.
· Designed For Action
I've joined the 'Drain Tube' Club also. The carpet behind the passenger seat gets saturated. That will be taken care of with next visit to the dealer in about a week. Also, the LED in my fog light switch is out and I have 2 small tears in my shifter boot. That's 2 more items for dealer repair. :rolleyes:
1 - 20 of 46 Posts
