Water leaking in on Passenger side
22205 Views 45 Replies 23 Participants Last post by  trixy31290
Well after having the car since September and just a tad under 10K miles. My Car is starting to leak right behind the passenger seat and drivers seat right above where the seatbelt comes out of the side panel. It was pouring here today and I noticed it when I came out of the store. So Im going to call the dealer tomorrow and make an appointment. Its either getting in from the window or the sunroof. Its closer to the side windows. Has anyone else had this problem on the coupe?
I must not have any luck with pontiacs. My last pontiac was a 87 formula and the t-tops leaked on that too. :(
41 - 46 of 46 Posts
Yep add mine to the list... I have a 2006 GTP Coupe. 30k miles. Water on the passenger seatbelt and by the rear window. My warranty is up but I took it for the same problem before so hopefully they'll fix it at no charge.
Does anyone have a link to the recall for this? I have a 06 G6 Coupe and my seat belts have been soaked as it's been raining the past weeks. Is this something simple to fix? I don't have a warrenty on this anymore. thanks
My son is driving a 2006 Sedan (41,000) with power sunroof. After a good rain he found water in the overhead control console (dome lights) where the power roof switch is. Anyone else have the water dripping into that area from a plugged or disconnected drain hole tube? He has the car at college so I will have to wait til it gets home to check.
Any one with a similar experience and fix would be appreciated.
Mine's an '06 coupe. Had squishy seatbelts AND gunk in my front light. Had the tubes replaced and everything is 100% now (it's been raining like crazy here in St. Louis the past couple of days and inside the car is bone dry).
To check on recalls give your dealership service department a call and have your VIN on hand to read to them. They can check all recalls your vehicle is eligible for in a matter of seconds.
Hi I had the same thing happen to me in my 06 g6 coupe... I will say that when it happened I had left the sunroof propped open and it rained quite a bit that night. My sunroof stopped working and there was water in my dome light. I was lucky to still be under warranty and lucky that I had spotted the water by the seatbealt before this happened. I told the dealership that the water by the seatbelt was the cause of everything. Your best bet is to take it to the dealer because it could short out electrical parts in the car. I don't think this helped you much but that was my experience.
So I'm getting my car checked out tomorrow to find out where it's leaking from. (Theres water under the back seats, all in the trunk, and my seat belts are soaked. They said it's probably a drain tube. About how much does this cost to get fixed? They are doing a free water test for me. Thanks
41 - 46 of 46 Posts
