I recently bought a salvaged 2007 Pontiac G6 3.5L without a key fob and I was wondering which one do I need or do the numbers on the keyfobs matter? Does my 3.5L G6 come with remote start and how can you tell.
Let me know if you need more info
If you have rpo code AP3 on the sticker inside your glove glove box, you will most likely have a remote start. You will want to buy the 5 button remote key fob that replaces part # 22733524. I ended up having to hire a fellow to cut my new key and programmed my key fobs.
You should check to make sure the safety switch on the hood latch functions properly and the remote start is turned on in your radio settings.
Good luck.
