I recently replaced the battery on my 2009 GT. Since then, whenever I open the driver side door, I have a message "CHANGER PARKED". It goes off after about 7 seconds. I cannot find this message in the manual. Anyone know what it means?
I read somewhere that it has to do with you changing out your battery. Because the old battery was weak, it kept resetting ur radio. I read the solution was to cycle thru ur cd changer and play cds to reset it and then the message won't come up. Not sure if it'll work but worth a shot.
JT
It got left out of the owners manuals.
#PIC4509A: Radio Displays Changer Parked Message - keywords battery CD display int intermittent intermittently no owners park radio - (Dec 27, 2007)
Subject: Radio Displays "Changer Parked" Message
Models: 2004-2007 Chevrolet Malibu
2008 Chevrolet Malibu Classic
2005-2008 Pontiac G6
This PI was superseded to update models and model years. Please discard PIC4509.
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
Condition/Concern:
A customer may comment that the radio will display a "Changer Parked" message intermittently at times, and there is NO explanation in the owner's manual for this message.
Recommendation/Instructions:
This message will display after the CD mechanism has initialized or when you manually park the CD mechanism. Initialization occurs normally upon a battery reconnect. The mechanism will unpark itself once you press the CD load button.
Note: After pressing the CD load button, you will NOT get a message that's it's unparked.
Well wasnt toooo far off. Thanks greenman.
JT
Thank you all so much - I truly appreciate the help. Answer worked like a charm! :)
