if i want to replace the head unit, speakers, and install subs what all do i need other than the speakers, a new head unit, subs, an amp for the subs, and enclosure, and the connectors for the speakers?
Depends on if you want to retain the DIC. Either way you will need:
-Headunit
-Speakers
-Sub(s)
-Sub Box
-Mono amp (or 5 channel if you want to power the speakers with an amp and dont want to buy 2 seperate amps)
-4 channel amp (assuming you want to power your speakers off an amp)
-power wire (i would recommend 0 awg)
-RCA cables (1-3 depending on amp choices)
-Speaker Wire (18-16awg for speakers, 14-12 for sub)
-an antenna adapter
-fuse (amp rating based on the wire you are running)
-fuse box
-wire terminals (the things you put on the end of the wire to connect to the battery terminals, but i cant remember what they are called:eek:)
That should be it. I dont believe im forgetting anything.
But, if you`re going single DIN you will need the Metra 99-3303. If you are going double and want to retain the DIC you will need the 99-3303 and the additional double DIN dash piece from Metra. If you dont want to retain the DIC you just need the additional double DIN dash piece from Metra.
