1 - 17 of 17 Posts
2008 Pontiac G6 GT hardtop convertible (3.5L, 185K miles)
While working in my trunk, a very corroded wire broke. Can anyone tell me what this is used for? I tried to trace it, but it disappears into a wiring loom, never to be seen again. We're looking at the driver's side of a convertible trunk. (I haven't tried operating the convertible top, not until I figure out what this is.)
I scanned the vehicle for codes, and there were none.
17926
Discussion Starter · #3 · (Edited)
Yes, the wire frayed and corroded. I’m sure I can clean it up and solder it back together, but I just want to know what this connector is.
EDIT: It's a brown wire and a white wire. The thick copper wires are stranded cable as opposed to solid cable.
· 08 convertible
All automotive wire is stranded. Never solid. I wouldn't worry too much about identifying it, just fix it making sure each wire goes into the correct position. It's a safe bet it's there for a useful purpose. I don't know what circuit that cable is part of.
17928
Although you didn't specify the year, in searching through the PDF of the factory manual, this is the best I could come up with. My guess is that it's either 6 - 12. I'm leaning towards 12 because of what you said about it being "stranded". I'm assuming you mean like cable TV coax correct? That would make it the AM/FM antenna wire.
No, he means stranded. Those wires go into a normal 2-pin connector and coax cable cannot use that kind of connector.
I understand that. What I was attempting to understand was what he meant by "stranded". Did he mean the core or that there were multiple wires in the insulation like a network cable? All automotive wiring utilizes stranded cores so that they're flexible to go around corners and not break from metal fatigue due to vibration. The picture does not show a "normal 2-pin connector" as you can see around 8 wires sticking out of both it and the severed cable. Therefore, I thought he might have meant a shielded cable (like a coax).
I'll have a look at mine in the morning and see where it goes.
@Bill Brown ...Bill is that pdf manual avaliable for download somewhere?
Thanks
Yes. It's actually a thrown together hodgepodge of several different manuals that someone tried to make into a comprehensive one, but it ends up being incredibly difficult to navigate. If you'd like a copy I think I can put it up on Dropbox. I'll let you know the address when it's up.
Discussion Starter · #12 ·
Thanks, everyone! It was indeed the rear defroster wire. The connector had somehow melted, so that couldn't be saved. I spliced and soldered in some new wire, used two plastic caps in case it has to be disconnected, and it seems to be working great. I'll test it when things cool down.
ConvertMe: I live in the northeast United States, so this is an important feature any other time of the year.
Discussion Starter · #13 ·
So, I had to cut off the connector and strip back some clean wire:
17962
I won't bother showing you my hackneyed repair job or my terrible soldering abilities, but between solder, heat-shrink, some copper wire from my computer's failed UPS, and a cheap (very cheap) soldering iron, I managed to get it done. I used those plastic electrician caps in case it ever needs to be disconnected, because I don't have the skill to solder on a new connector.
17963
17964
I opened and closed the roof a few times, just to make sure nothing would get caught, and my repair job actually worked! I'll test the rear defroster next winter, when I can actually tell if it's working or not.
17965
Why is the hood open? I forget.
Service Manuals show up from time to time on eBay as electronic versions from DVD. I have a copy, and I think a few others do as well.
It's can be a little tricky to install on a laptop, but well worth it.
I got to repair my defrost wires a few years ago, same thing, melted the connector all to hell. I went ahead and deleted the connector and did a solder splice.
If I ever have to remove the entire roof and have to cut that splice, defrost is likely the least of my worries.
I bought the entire 3 book Service Manual set for my 2007 on eBay, but I already had the hodgepodge .pdf that someone had thrown together. I've got the .pdf one posted in Dropbox. If anyone would like a copy PM me and I will send you the link.
1 - 17 of 17 Posts
