I replaced the stock stereo with a really great Kenwood system; and I also installed a new Sirius XM tuner to that stereo so that I could continue to have satellite radio with the new system; the new Sirius XM tuner uses it's own antenna.
I would LIKE to be able to connect the factory installed "shark fin" satellite antenna which is already installed on top of the car, but I am not sure where that antenna leads or even if it is worth the bother - is it under the dash? inside the trunk?
I just wanted to ask before I wasted too much time.
Thanks!
It's located behind the passenger front kick panel, up a little high.
Found that here: http://www.g6ownersclub.com/forum/showthread.php?t=6044
But my program is telling me for the sedan that it's located on the right side of the rear window shelf, and the Vehicle communications interface (for the key fob) is located at the right end of the dash, IE kick panel high up. Unfortunately I don't know for sure where it is.
