Have a 2008 G6 - 4 dr with roughly 88K miles
.... My passenger side window currently does not roll up if you use the passenger side control, only from the driver side.
Also have had to replace both sockets in the headlights as both were fried.
Recently had the check engine light come on reading - Cam shaft timing over advanced
Also , my factory cd player was kind enough to eat a cd and never eject it...
I keep up with maintenance on the vehicle .. I do my own oil changes to verify the correct weight/viscosity is put in ... I have had to have factory replace the battery about 30K miles ago.
Anyone have any issues with any of the above ???? Any ideas on repair..
Thanks in advance
Probably the pass door switch but I would test it with a DMM first.
Common problem. I hope they put dielectric silicone grease on the replaced terminals.
I would need the exact code number to help with that.
The OEM cd changers, like most cd changers, are problematic. I switched to an Ipod a long time ago & never looked back.
