I recently replaced one of the burned out tail lights. Then all of a sudden the interior dashboard lights, lighting on my shifter and brake lights do not light up unless I brake.
Explanations anyone?
Pontiac Enthusiast
Sounds like the wires are plugged into the wrong ports... I accidently plugged them into the wrong ports and it did the same thing, go through each individual one and make sure that they are in the right place... you can always look at the other tail light and compare wires to make sure they are in the right place... that's the only thing I can think of to cause this problem..
