My Wife's G6 is a 2-door hard top. I have an intermittent problem when you open the doors the window is suppose to go down about a half inch, forgive me I don't know what this action is called, and then go back up once the doors are closed. Something is wrong with this action only on the passenger door. The window will drop as supposed to but once the door is closed the window will not go back up. Also the Automatic window on the passenger side doesn't work, all the while the driverside door works fine. But the passenger door window will go up and down all the way. Any suggestions?
I believe that is called window "indexing". I think there's a procedure in the owner's manual for recalibrating the indexing function. Check your owner's manual if you have one. If not, I can go look it up in mind and post the procedure.
