windows wont work
3346 Views 1 Reply 2 Participants Last post by  Tupperware SC2
My windows wont work anymore replaced blown fuse and it immediately blew again. I've heard this is an issue with G6's.Anyone have this problem or suggestions for fixing it.
thanks
if the fuse belw immediately then there is a short in the wiring. that could be real tricky.
does it pop as soon as you hit the switch or when it is put in?
if it pops when you put it in there is a short before the switch. if it pops when you hit a specific window then you know the trouble is between the switch and the motor.
do your self a favor and get some leads and a remote relay. that way when you are trouble shooting you dont go waste 432432143 fuses. the relay will pop then reset, just like the breaker in your house.
