Just got an 09 G6 GXP, several issues due to previous owner negligence. When I fill the gas tank, the car will not start. It currently has the evap emission engine code, and a cat code. I find it will start sooner if I floor the gas pedal. Anyone ever experience such an issue
Any update on this? I have the same issues. Same model and year
If you were to post the code numbers, that would go a long way to providing you with meaningful repair suggestions. BUT my bet is canister purge solenoid mounted on the motor.
That helps a lot. YES my suggestion is one of the possible culprits causing the problem. AND the easier of the fixes beyond a possible gas cap. A google search of the code will help you A LOT.
