my Kids car
my daughter has a 08 G6 4cly.
right lower ball joint is getting loose , she drives a lot of gravel roads.
then the front end started to shimmy, found loose ball joint, but also dirt/gravel build up , un-evenally in front wheels(steel with wheel covers).cleaned wheels out and car is ok now .
question is..... is there a measurement of play with a dial indicator.
or ,if any looseness,the ball joint has to be replaced, which is serviced only with a complete lower control arm
thanks , Keith
My 09 rattles like a wagon, not sure if it's ball joints or tie rod ends. These horrible Michigan roads don't help matters either. Probably looking at a major repair bill.
