Just had my '06 GTP coupe in the dealership for the third time to try and fix the XM radio. When you set the presets for XM 1 , they also mysteriously appear on XM 2 , overriding the original presets.
Doesn't happen all the time, sometimes only every few weeks. When you shut off the car, and restart, it starts working. After working on it for three days , and forcing me to drive a '06 Caddy DTS as a loaner :D , they called to say that GM engineers are aware of the problem and are working on a fix, and I'll be notified once they decide how to fix it. They think it's a software issue. Seems like it would have been easier for them to just swap out the radio, but that's GM.
Sounds similar to the problem I had where I would leave the XM on one channel and remote start and it would be on a different channel when I got in and turned the key. They got a reading on Tech II that the voltage on the radio was running low. They replaced the radio.
Discussion Starter · #4 ·
Never really thought about it but, I always notice it on the ride to work, and I have been using the remote start every morning. Once it's been shut off and re-started, seems like the problem goes away for awhile. Just a PITA thing !
Bob G said:
They got a reading on Tech II that the voltage on the radio was running low. .
Did that fix it? I am familiar with Tech 2 and it doesn't provide very much help when diagnosing XM issues - very little data is made available.
The tricky thing is that the radio head actually doesn't store the XM presets. On this vehicle the XM receiver in rear of vehicle stores presets. The radio head just sends a message to the XM receiver that the BAND or Preset 1-6 button was pushed and then assumes (which it displays for you) what band (XM1 or XM2) the receiver is providing presets for. The XM receiver does pass back channel and song/artist info but never actually what band of presets it is using.
Sorry I don't know any more than that :)
e2, I don't remember the exact message but it did display "low voltage" in whatever the rest of the message was and because of the message they replaced the radio (and forgot to bolt it in when they assembled the dash back so they had to disassemble it again :eek: )I also had a prior problem with the 6CD changer getting discs stuck and not ejecting but after the radio was replaced it has worked flawlessly.... keep in mind that all mine did was jump stations or catagories (rock to country for instance), not bands like XM1 to XM2. It actually stayed on the XM1 band itself.
e2helper said:
I thought I explained pretty well what the problem was :p
I can check with the dealer to try to get the XM receiver checked. I'd rather have them do that than try to rip my dash apart to get to the radio, which with my luck would provide with me with some nice new rattling sounds from the dash. :p
