finally the car just got assembled and put together after paint.. if you guys didnt know i had the gxp that was hit driver door/fender side ..everything has been fixed and put back properly but i have a problem! I had to buy a door to replace the one that was hit, dont know what year it came from but i know its from a coupe ..they should all be the same no? anyway the door was modified to open and close like oem, no different BUT if you ever owned the coupe or know about it you know that the window opens and closes when you open or close the door, my window goes down more then enough but does not go back up, wtf is going on ?!
You need to do the index relearn or whatever it's called on the window. It's in the manual.
