Status
Not open for further replies.
21 - 40 of 127 Posts
Attention if anyone needs a specific wiring diagram just message me I have All diagrams available because I have the GM workshop service manual if you only need one I can email it for free if you need multiple it'd be a small fee for my time I also have any repair guide that you may need also all years I can even input your VIN NUMBER to be specific
Hi, I have some seats out of an 05 G6. They are black leather power heated seats and I'm going to be custom fitting them into my 04 Impala LS but I don't know witch wires go to the heating. They have the power switch for the seat heater on each seat and I can't find the wire diagram for those seats. I don't want to power the air bags on the seats so I'm really needing to know witch are for the heated seats and for the power seat. The driver seat is the only one with power but both have heated seats. Could you please help me with this?
Thanks,
Jason,
I need the grounding diagrams for trans and starter
Hello, do you have a starting and charging diagram for 2009 Pontiac g6 2.4 liter 4 speed
I have a 2007 Pontiac G6 SE model and I'm trying to hook up a aftermarket radio it's a pioneer 1200MP model my car vin is 1G2ZG58NX74112036 I need the radio harness color wires how to hook it up.
Discussion starter · #29 ·
Smashing, Knightal: I want to disable the utterly annoying four bells when one of the 27 computers detects a need for service as when the Traction Control needs servicing. I'll still see the 'Service Traction Control' very brightly on the readout window so I won't forget, but until foul weather reappears in six month I don't give a hoot about Traction Control.
Hi we could use the engine performance wiring diagram for a Pontiac g6 please. Thanks Pat Stark ppucky45@hotmail.com
Do you have or can you get the convertible top wiring diagrams and can you find out what voltage and amperage goes through the micro switches for the top positions. I don’t have any problems with the t at the moment but I’m looking for all the inf I can get for future reference.
I posed a fair few of the schematics in this thread / post. Perhaps they would be of use.
need wiring diagram for 07 g6 monsoon radio. wanting to swap with 08 torrent radio if possible Thank You
Maybe these will help. The Monsoon amp takes speaker level inputs, so it is really just matching the speaker wires with a harness adapter and supplying the power signal. My new radio has options for resistor based steering wheel controls so I had to add a vire to the metra harness adapter I used to pass these through.
VIN # Pontiac G6 1G2ZG57B694182255 and shop manual or repair manual which ever is more likely to have wiring for the nuissance bell. Best Always Chaz chazvanheyden@gmail(dot)com
which ever is more likely to have wiring for the nuisance bell
The warning dinger is part of the instrument cluster for most models (I think it changed for the 2009.5 or whenever they changed the radio and moved the DIC to the instrument cluster). You could make the swap to the updated instrument cluster or you could remove the sounder from the existing instrument cluster board. The sounds are activated via the GM-LAN as best as I know, so there isn't a wire to cut.
If I remember correctly, there are only about 3 or 4 solder joints holding the sounder to the board. If you didn't feel comfortable removing it, you may be able to put some tape over it to reduce the volume. Note that the dinger is also the turn signal sound so you will lose those as well
Are you still available to send wiring diagram? I have 2007 Pontiac G6 convertible, 73k miles. Had for almost 1 yr. Need to get wiring diagram please, as car didn't have manual. I'm also looking for aesthetic parts/covers etc. Any help or advice/direction greatly appreciated. I will love this car, but I've already put $2000 in it, still smaller issues, and so hard to find parts.
Thank you,
Rebecca
Status
You have insufficient privileges to reply here.
