Status
Not open for further replies.
41 - 60 of 127 Posts
Attention if anyone needs a specific wiring diagram just message me I have All diagrams available because I have the GM workshop service manual if you only need one I can email it for free if you need multiple it'd be a small fee for my time I also have any repair guide that you may need also all years I can even input your VIN NUMBER to be specific
Good afternoon, I am trying to find the wiring diagram for the fuse panel. On a 2006 Pontiac G6. Cylinder the fuse panel in the trunk. As the taillights keep blowing the fuses. I am trying to track down the wire. That might cause the issue, possibly. I can locate an email for you. My email is jennifergrout@gmail.com
@jennifergrout , the brake schematics are in this thread.
I am currently looking for the wiring diagram for the fuse panel in the trunk of the car.
can i please get the incar wiring diagram tp a pontiac 2006 g6 gtp my harness got cut from driver seat to trunk and i can figure out how to rewire it
Hello everyone I didn't realize how many have commented on this so ya the Chilton online thing has expired but I do have a workshop manual in PDF form available in my Google drive I'm attaching the link below it has trouble codes as well its all in separate chapters g6 - Google Drive
Hello @Knightal, hope all is well. I looked through your googledrive and cannot locate 2007 g6 gt 3.5 Convertible schematics. I am in need of the 5 volt and low reference schematic and routing diagram.
Vin is 1G2ZH35N974274004
THANKS A MILLION!
My 2009 Pontiac G6 gt. Has had a reduced power sensor for a couple weeks. Cleaned throttle body but it still seems to to getting worse.. I d like to have the schematics for the throttle body and to the accelerator showing the connector harness.. I've heard those models have wiring problems. As it is too close to the engine in front and causes the wires to melt.. I'm not a real good parts changer I'm a lot better with an ohm meter. Id at least like to have an idea of what I'm looking at. stroglin@yahoo.com. many thanks for your valuable time. And any suggestions.. sunny
Ps. About the same time my cruise control stopped working. So I m really thinking it's the wiring..
As of now it will start and idle great but no power to drive..
I have a 2006 Pontiac G6 2.4l sedan and i could use the wiring diagram for the dome light, rear defroster, and radio antenna. Only a quarter of my back windshield gets defrosted and now if I listen to the radio and then I turn the defrost on the radio station turns to static the dome light I was having issues with as well. I will take any of the wiring diagrams that you have for my model it seems to have a lot of issues. Thanks in advance, you've been a big help already!
Hello I was needing the color codes for wiring of a Pontiac G6 2009 for the wiring system
Hello I was needing a color coded diagram for wiring harness for a Pontiac G6 2009 for the front end
Please send me the wiring diagram for 2007 Pontiac G6 gt convertible 3.9l coupe
Hi I need the complete list of all 5v references for 2007 g6 3.5l plz I'm tryin to solve the engine reduced power
I'm about to install a remote start on a buddies 05 pontiac g6. Not sure what all diagrams I'll need but whatever you could email me would be so helpful and appreciated. My email is sandshawn51@gmail.com. thank you for your time and generosity..God bless!!
I could really use the diagram for the rear lights. I upgraded to LED bulbs and I need to add resistors.
Thanks!
Yes I do the engine speed was reduced as we were driving then it said engine disabled it started one time what about 2 miles and quit again both times back door was opened at the same time the diagnostic read engine lspeed reduced then engine lock symbol came on won't turn over when I try to reprogram the key the engine lock light stays on for about 7 seconds then turns out any ideas anybody I could really use a wiring diagram for the engine lock system.
Status
You have insufficient privileges to reply here.
