Status
Not open for further replies.
61 - 80 of 127 Posts
Attention if anyone needs a specific wiring diagram just message me I have All diagrams available because I have the GM workshop service manual if you only need one I can email it for free if you need multiple it'd be a small fee for my time I also have any repair guide that you may need also all years I can even input your VIN NUMBER to be specific
Could I get the wiring diagram for the 2009 G6 GT Convertible 3.9, anything related to the convertible top
I bought a used 2008 Pontiac G6 2.4L 4 Cylinder for my teenage son but there is a wiring issue and we've been told that he needs to purchase and install a wiring harness. Do you still have wiring diagrams available for this car?
I need the original colors and a detailed diagram of the stock harness for the stereo ended up cutting them thinking I could hardwire a stereo in like I used to, nope I was dead wrong so I had to buy a stock harness and now I'm having trouble matching up the pins in for a 09 Pontiac g5
I need manual for 2006 G6 if you can email it plz. I'm having issues with it starting I turn the key and there's nothing no click no sound at all but my battery is good all lights and everything come on it just does nothing else
I'm having weird electrical problems with a 6-month-old replacement headlight. My friend says he can only help me if he has a wiring diagram. It's a 2008, 2.4 liter 4 cylinder engine, 4 door sedan. Thank you!
Looking for body control module wiring diagram for a 08 g6 gxp has the 3.6 vvt with a 6 speed have issues with the after blow features fan continues to run until relay is in plugged or battery drains
I was looking for pin # d10 in the body control module.... preferred to have the body control connection wiring diagram so I know what color and what pin # each wire runs to....Thanks Mike
I would appreciate a wiring harness for under the dash of my Pontiac G6 GTP 6 speed please. My email address is kstrudo72@gmail.com. thank you very much.
You can find a number of the schematics here - Power Distribution Diagram Index — 2007 Pontiac G6 V6-3.5L Service Manual | Operation CHARM Diagrams 4 as an example
The BCM pinouts can be found here - Body Control Module — 2007 Pontiac G6 V6-3.5L Service Manual | Operation CHARM
Vin# 1g2zm177484301660 would like the wiring diagram for the body control module connector trying to find the color code on D10 for the blower resistor module...the after blow feature does not shut off unless u pull the fuse momentarily so I want to wire a relay and connect to key on power for this issue rather than replace and relearn the BCM thanks Mike
Body Control Module — 2009 Pontiac G6 V6-3.9L Service Manual | Operation CHARM
You can select different engine and year if required. Also note that the after blow is a dealer option that can be enabled / disabled with a tech II or similar advanced bi-directional scan tool. Might be easier to have it disabled if you can find someone with the right scan tool. Good luck getting it sorted
Can you send me one for a Pontiac g6 2006 please to everstuff2022@gmail.com. thank you
Status
You have insufficient privileges to reply here.
