Won't start.....No Fuel Pressure
2007 G6 3.5
Started this past weekend while driving, it would just die, but could be restarted. Then yesterday it would not restart after it died. Now it wont start at all and no fuel pressure.
Checked fuse and swapped relay with no change.
Verified power to the connector that goes to the fuel pump, I have a constant and two key on power wires. I forgot to check the ground before I pulled the gas tank but will do that next.
After the tank was out I decided to check to see if putting 12v to the pump would turn it on and yes it started to squirt fuel, but in the car I did not have any pressure at the valve on the fuel line under the hood.
Is the fuel pump controlled by another means like crank sensor?
2007 G6 3.5
